In Wildfire 4.0 "Drawings" you could click in a view "right click" and pick use in model tree. Then go to the model and pick a plane or coordinate system to dimension to. In Creo 2.0 this option has been removed. You can display planes or coordinate systems and try to pick which one you need from the drawing view but if you have a large assembly it is very hard to pick the correct one.
