Dynamic Drawing View Scaling
When placing and editing a drawing view, enable the use of the view outline corner drag handles to dynamically change the custom view scale!  This simple visual method of placing/sizing views would save considerable time.
3 Comments
banderson-2
1-Newbie
It would be great if it was both scales, not just the custom. Maybe when you double click the default scale in the bottom of the screen, you can type in the number, or use a dynamic drag handles. Then it would work in the custom scale as well, when you have the scale field selected, you can type in a number or use the drag handle.
That's a pretty slick idea!
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
