Dynamic time simulation can't simulate anti-vibration mounts !!!!
0 Kudos
Hallo,
Every real vibrating system has anti-vibration mounts to isolate the system form ground.
Today there isn't any possibility to simulate this into Creo simulate. This is serius lack because the
vibrating system is strongly influenced from the elastic behavior of its mounts.
I suggest to implemet this by adding a two way spring table: today you can input the spring stiffness, and
the spring use the same value of the stiffness both in extension and compression condition.
It would be sufficient if it were possible to set two values of stiffness, one for compression, the other for extension
condition in order to simulate pre-loaded elastic supports.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
