At the moment the ECAD assembly does not support Simplified Representation for the management of the flat state of the PCB (components do not follow the board part keeping their position).
It would be very helpful to add to the Flat Pattern tool of the ECAD assembly the same improvement of the sheetmetal part, in which is now possible to create Flat Pattern state via Simplified Representation.
Flat Pattern of ECAD assembly supports only the Family Table
Flat Pattern of Sheetmetal part supports also the Simplified Representation
