When making the command explode in configurations is possible to see during the command wireframes which indicates movement of the parts.
Will be very helpful to keep it after the command is finished because many times those lines are needed on the drawings and actually many customers make them manually in Annotation.
Now wireframe is viewable in Annotation, so is enough to automatically create a container with exploded movement wireframes inside.
