Need the ability to Customize the EZTOL reporting to include Company information like Header, Logo, and other information. Yes the full application can do this, but it should also be able to be done in the PTC integrated application if that is all that the customer needs.
When most Analysis of 2D calculations is enough, then only the PTC Add-in should be able to be used, but with still having the custom reports.
This presents allowing the company to use corporate standards when sharing the Stackup reports/information with other teams.
