Add the ability to change/show parameters units easily on Creo drawings without having to create additional parameters.
Use case example: It's very common for to model in one unit system but to want to display some parameter differently on a drawing. Specific example - 3d model in mm-kg-s in Creo but this makes the volume parameter in mm^3 which create a huge number that is difficult to read on a drawing. Displaying in cm^3 makes more the information easier to read.
The current functionality to show units on drawings requires several extra parameters, is difficult to setup, and doesn't display the units well - https://www.ptc.com/en/support/article?n=CS126392
