Edge Display vs. Thread
When using the Edge Display → Hidden Line, thread is missing.
There is advised a workaround on PTC sites.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS69090&art_lang=en&posno=1&q=Edge%20Displa...
I think, that is a fault.
As you can see on the link above, if I need this functionality, I have to submit new product idea.
So I do it ...
Thank You in advanced for Your votes.
Regards
Martin Stary
2 Comments
Regular Member
I would add a datum plane through the hole center
then create an intersection curve including the datum plane, the threat quilt and the hole surfaces
this curve can be managed via model layer and represented in your drawing
this solution allows you full control about display, style and visibility
Community Manager
