When you have a sketch with a bunch of holes, and all of the holes are the same diameter, so you dimension one of them and then use the “equal radii” constraint to make them all the same size. When you go into your drawing sometimes when you show the hole dimension it isn’t in a good place for it and you want to move it to a different hole in the view/drawing. Since all the holes are the same, because of the equal radii constraint, it would be nice to be able to click the shown dimension and have the “edit attachment” button work where you can move that shown dimension to a different hole location that works better with print/view. This works when you have created a bunch of rounds in the model, you show the dimension, and then pick it, and click edit attachment and all the rounds of that size in the same feature highlight and you can pick a different round and the dimension will move to that radius. Would like the same thought process to be done with sketched diameters, radii or equal length lines when they’re constrained as such in the sketch.
