Edit defintion of a hole by drilling tool to be able to convert a hole in thread and vice versa.
 It is important during construction to have the possibility to convert a hole that has been created with the drilling tool into a thread or vice versa. It is often not clear at the beginning of construction which type of drilling is needed at the end.
Deleting and re-creating is very time-consuming and complicated, because it may already have been referenced to this design element.
3 Comments
alpine_hosokawa
3-Visitor
is very importand
StephenW
23-Emerald II
You can change a hole to a threaded hole and then back. Maybe you are trying to change it after you pattern the hole.
One you create a pattern, it won't allow you to change it.
If that is the case, there is already an existing idea here https://community.ptc.com/t5/Creo-Ideas/Patterned-hole-redefinition/idi-p/458774
olivierlp
Community Manager
Status changed to: Archived
