Edit the tolerance of a dimension in drawing by using double click, like in the Part-mode. To have the same method.
I the drawing it is usually more common to change the tolerances and so it is noticeably easier.
In Creo 2.0 M110, PTC change the behaviour what is happening, when double click on a dimension in a drawing.
Now you can edit the dimension directly, no need to go in the properties.
So it would be the next step, if its possible to change the tolerances to by double click on it.
