Editing a Sketcher Spline with Analysis and Dimensions/Constraints
Within a sketcher we can't edit a spline point that has any dimensions or constraints when the spline menu is active. We want to see the analysis of the spline and then edit the dimensions as required. We need to first close the analysis, edit or delete the dimensions and then go back in and check the analysis. Or we need to delete the dimensions and constraints and THEN we can manipulate the spline points in the spline tool.
1 Comment
BrunoTHERY
3-Visitor
My problem is that I can't activate the control points in the edit tool and therefore create the control polygon.
Translated by Olivier Le Pord using Google Translate on Aug 31, 2022
Mon problème est de ne pas pouvoir activer les points de contrôle dans l'outil de modification et donc de créer le polygone de contrôle.
