To Simplify GCRI usage workflow, PTC need embed newer release readnewermodels.dll file into old release by default and enable this functionality via a config.pro option only.
It is Inconvenient to copy the readnewermodels.dll from newer release and then paste into old release. For example, if want to open Creo 2.0 file into Wildfire 5.0, but Creo 2.0 installation is not available, it will have to copy from other company.
