Test step short description | Time 10.2 F000 IE10 / s | Time 10.2 F000 Mozilla embedded / s | Difference 10.2 F000 Mozilla embedded /IE10 |
(1) Search for assembly | 2 | 2 | 0% |
(2) Add to Workspace: time until "Download succeeded" | 563 | 1262 | 124% |
(3) Workspace Refresh | 14 | 24 | 71% |
(4) Open dialog: Save As | 3 | 6 | 100% |
(5) Save As: collect required dependents | 106 | not finished after 15min | not finished after 15min |
(6) Save As: cancel dialog and workspace refresh | 3 | 1 | -67% |
(7) Save As: process for one assembly | 45 | 51 | 13% |
(8) Syncronize and Workspace refresh | 35 | 46 | 31% |
(9) Open dialog: Remove from Workspace | 65 | not finished after 10min | not finished after 10min |
(10) Remove from Workspace is processed | 206 | not possible as it depends on the previous step | not possible as it depends on the previous step |
Use the Standalone installed Firefox version on the machine for embedded browser. This is regularly updated by Mozilla and updates run by the user and contains all necessary security fixes and other improvements
Provide latest Mozilla updates for embedded browser of all Creo Releases and datecodes that are maintained. The updates should be possible to execute separately to a datecode or release update. This ensures that a datecode update is not forced by a security issue in the embedded Mozilla browser.
