The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Enable dynamic edit in assembly mode.
Current state:
Features added to assembly component are not visible in the assembly until it is regenerated.
According PTC:
Dynamic Edit is available only if auto regeneration is enabled.
Set config.pro option ENABLE_AUTO_REGEN YES
Dynamic Edit is available in part mode only
Request:
Enable Dynamic Edit in asembly mode., so that modification perfomed on the component are visible in the assembly (without regenerating).
5 Comments
psobejko
How about being able to edit the positions of the components dynamically? (right now you "edit" the component, type in the new dimension values for the placement / rotation of the component, then regenerate to see it and its children in the new place).
makelley
3-Visitor
This functionality would be very useful for me, as I am often adjusting dimensional values to affect aesthetics.  Dynamic modifications being restricted to part mode only forces me to switch between windows frequently; it would be much better to visualize the assembly as a whole while doing this.
ggalli
6-Contributor
This functionality would be very useful for me!
makelley
3-Visitor
Dynamic Editing Mode is great; and would be even greater if it were available in the context of an assembly...!
olivierlp
Community Manager
Status changed to: Archived
