There are various good reasons to use assembly cuts in your models; and there is often a necessity to use surface regions when setting up a Simulate analysis.
Unfortunately, at present this is not possible as I believe surface (and volume) regions must exist at the part level.
A method to enable creation of surface regions on a surface resulting from an assembly cut would avoid the need for clumsy work-arounds such as duplicating the assembly cut geometry in each part (thereby losing design intent), or exporting the assembly as a STEP file before re-importing it and analysing it as a 'dumb solid' (thereby losing parametric capabilities).
