Currently skeletons cannot be moved from one assy to another using the restructure command. The skeleton can only be deleted from the first assy and then reassembled to the second. This is an issue if an internal copy geometry has been made to the skeleton within the assy from another model. Enable the restructure command to be applicable to skeleton models and retain all internal copy geometry between the skeleton and all other models within the assy hierarchy when the skeleton has been restructured.
