Automatic workpiece created by "Mold > Workpiece > Automatic Workpiece" only allows to specify mm or in: - With Units mm always generates a part with unit system mm Newton Second - With Units in always generates a part with unit system inch lbm Second (Creo Parametric Default) - Other unit systems are not supported and hence cannot be set Allow at least to set all predefined unit systems in Creo, e.g. MKS (meter kg second) or MMKS (mm kg second). Even better would be to enable also setting customized unit system, as it is possible for templates. The sibling function "Cast > Die Block > Automatic Die Block" for Casting should be enhanced the same way.
