The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Enable use of editing functions without first selecting geometry
In part mode, the majority of the editing functions (model tab -> editing group) are not available unless you have already selected the relevant geometry beforehand. This should not be necessary and can waste time in some cases. A better approach would be that selecting these functions automatically modifies the selection filter to corresponding acceptable geometry.
For example, to use the extend function I currently need to first select a quilt's edge and then I can click on the function. But my goal was to select all tangent edges using a rule-based selection in the extend function, so I need to go reselect the edge in the function anyway. If I could start with the function, I would save the first selection of the edge. It may not appear much, but it can stack up!
5 Comments
S_Edgenear
Isn't this already implemented in Creo 8? What version are you currently running?
sparadis
3-Visitor
It was true as of Creo 7 last year. I have not tried Creo 8 yet.
S_Edgenear
I'm using also Creo 7, haven't Creo 8 installed yet, but I think it's already implemented in Creo 8.
mneumueller
Status changed to: Delivered
It was delivered with Creo 8.0 and included:
  • A/O workflow support for features in “Editing Group” including Project, Trim, Offset, Thicken, Merge, Intersect, Solidify
  • Ability to switch between feature “Type” during initial feature creation (for many of the situations where the object type of the selected geometry drove what feature-flavor to invoke)
olivierlp
Community Manager
Thank you @sparadis and @S_Edgenear for your idea and comments. Thanks @mneumueller for your confirmation.
