Enable vertical text orientation in geometric tolerance
Geometric Tolerances with leader pointing to the witness line of a vertical orientated dimension should be able to have a vertical oriented text.
Meaning; text in line with dimension arrow, no jog.
Could be a subcategory of placement in Dimension, instead of 'under dimension' or 'under value'  the new one 'next to dimension'
Attached an image of the current (wrong) view.
2 Comments
csheridan-bebea
3-Visitor
This is already offered in several other CAD programs. It surprises me that Creo is unable to do this.
olivierlp
Community Manager
Status changed to: Archived
