Enhance 3D Thickness Analysis
Requested functionality does not exist in Creo 6.0
1)Needs a color map and show different colors for different thickness. Need a visual of all thicknesses instead of just Minimum, Neutral and above Maximum.
2)Make colors apply through-out the geometry not just on the outer surfaces. Allow dynamic sectioning after the computation so user can move through the model to view analysis.
3)Improve performance, takes a long time to run
4)Add Default Reference of SolidGeom
5)Keep 3D Thickness Analysis active until closed by user, so other tasks can be done at same time (measure, section).
Reference https://geomcaliper.geometricglobal.com/
5 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
olivierlp
Community Manager
Thank you for publishing your idea. We need more information as specified in the form you saw in the submission process. (Questions below - specifically #3). The more details and context you give, the better.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
WayneSchrock
1) Mold Making / Molding, What does my role matter to the idea? I am the CAD Manager. Anyone that evaluates part design for molding.
2) We are currently running Creo 2 & Creo 4. But as stated in Idea above the idea stems from lack of functionality in Creo 6.0
3) Inabliity to quickly find design flaws based on major wall thicknesses in part design. See the reference in idea post, this software should be incorporated directly into Creo. I should not have to purchase a 3rd party software package. We already purchased Creo Mold Analysis.
4) The same as one would want to use this current feature. Look at part design thickness.
5) Provide better detail information in less time.
olivierlp
Community Manager
Thank you for your idea and the information you provided.
olivierlp
Community Manager
