With PTC Creo Parametric, when you calculate 3D Thickness (Thickness functionfrom Analysis tab) to identify the areas on a model with critical thickness issues, the results displayed doesn't allow to see internal critical thickness issues with a lot of intersecting holes.
Please add a transparency on surface functionality in one of the next Creo releases.
Proposal:
