Enhance Global Interference function
Enhance Global Interference.
When performing a Global Interference in an Assembly with several hundreds of parts it's difficult to clearly see the interference especially now that the parts also highlight. By adding the option to view each interfering pair in a Simplified Rep while viewing the interference we can clearly see what we want.
2 Comments
korr
Regular Member
Or even change the colors.  PTC has done a horrible job with colors in Creo 2 & 3.
This is the case with draft check also. You cannot tell where you are in the part if you zoom in.
PTCModerator
Emeritus
