Enhance motion in Assembly and drawing: 'Position' functionality instead of current 'Snapshot-tool'
In Assembly mode:
- Just like simplified reps: add several Position reps, so different positions of a motion assembly can be saved.
- make it possible that 2 or more positions of parts in the assembly and drawing can be shown in the same view (for instance the extended and retracted position of a Hydraulic cilinder). The appearance of both Positions has to be choosable (for instance the first position as shaded and the second position as dashed line or transparant)
- add automatic envelopes lines/curves of movable parts
- Add a 'Position' tab in the 'View Manager' window (near the simplified rep) instead of using the current working method by using the snapshot feature in assembly mode
- Make the "Position"- state available in the Combined States, so combinations of the Position with a Simplified rep and Style can be made.
- Update it automatically when for example a new part is assembled, an appearance of a part is changed or the simplified rep is updated
2 Comments
mwa
Please Vote !
olivierlp
Community Manager
Status changed to: Archived
