Flatten Quilt is a powerful function of Creo parametric 3.0 . Some users need to add this function in the Creo E/D.
It can unfold some Irregular Bend areas (like FPC) that don’t need K-factor.
Not acceptable for engineers to create fillet for all bent areas. Quilt surfaces need to be unfolded when the model is unfolded.
like this picture
