Flatten Quilt is powerful function in Creo parametric 3.0 . Some users need this function in the Creo E/D
Not acceptable for engineers to create fillet for all bent areas. Quilt surfaces need to be unfolded when the model is unfolded.
It can unfold some Irregular Bend model(like FPC) that don’t need K-factor.
Below picture
