As of today hole table has the ability to show limited information about a hole.
basically it allow you to show X,Y & Diameter information and that's it.
in order to add further information you need to create special parameters, Manually for each feature and add them to table ( see recommended procedure here ) .
Having the possibility to read feature characteristics, by selecting from a list, would be a significant enhancement to tool capabilities.
A must characteristics would be Depth as it relevant for both Hole & Extrude ( remove ) which include for hole table.
