Exclude some instances of pattern using OTK Java + Feature Element Tree
Hello!
I created a pattern using OTK Java and FET. Now I need to exclude some of the elements of the pattern (just as is done with Creo).
For example, I have the pattern created using Java OTK and FET:
This is what I need:
1) disabling pattern elements.
2) the result that I need:
Since I created this element using FET, I know that it has a certain structure, the elements of which perform certain functions.
Therefore, I created the pattern without excluded elements and unloaded its tree into a XML-file.
And then I did the same with the pattern with excluded elements.
I compared two XML-files and they turned out to be the same.
From this I concluded that OTK Java + FET cannot exclude pattern elements.
Although this feature may be useful in some cases.
Best Regards!
