When making exploded views, if items are rotated, the exploded lines should come in as curves. A depiction with two linear segments joining at an angle is wholly inadequate. Sure, I can add 10 to 20 jogs, but just think if there was an option for an arc, the huge reduction in the number of clicks!
How it is:
How it should be:
