Currently, Manage Parts only allows you to choose what parts are visible in an assembly. This would also be very useful to apply to parts in the situation where you’ve got a part that you want modeled in the as-used state, but need to document the as-manufactured state. For example a piece of tape that is die cut, but drapes over the top of another part. The model that is in the main assy would be the tape in the shape of the parts underneath, under that model would be a container, in the container would be the as-manufactured model that is used in the drawing.
Sample structure:
MainAssy
- TapeInPlace
- MfgContainer
- TapeAsManufactured
- ViewSet
