Extend undo feature inside cabling environment
Undo (crtl-z) is working in several areas of Creo Parametric but not in Cabling environment.
In particular, when we want to modify the network after the first routing. If we move a location to a plae that make the routing fail, it's hard to revert back into the original state. Same consequences when we delete a position.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
