The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Extrude Cut the quilt from all the parts in assembly level.
The "extrude cut" function (in top assembly) can remove the solid material from all the components at assembly level. - --some solid component will be fully cut, some will be partially cut depending on the cutting sketch size.
I want the similar function "extrude cut" on quilt (surface) for all the components in the assembly level also.
---Some quilt in the component can be fully cut, some can be partially cut.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
