Currently in Creo 2 you can make extrude that is not adjacent to base sketch like in pic1 by adding "-" infront of blind distance. Unfortunatly you can`t do same thing if you use "blind" for both sides it only works if one side is defined by "to selected". If you add "-" when "blind" is set to both sides of extrude they just switch places.
Enhancment: Allow extrude not to be adjacent to base sketch when using "blind" on both sides of extrude by ading switch icons or keeping the "-" infront of number like in pic 2.
Picture 1.
Picture 2.
