I know it can be done many ways however a direct option when creating extrusion will be very helpful. "Extrude upto offset from a surface"
For example, when we create a plate which should have terminated before 10 mm from any surface. I need create two features. One extrusion upto that surface another cut 10 mm from that surface. One option "Extrude upto offset from a surface" will be useful and logical I guess.
Jayanta Sarkar
