[Eztol] Diameter/Radius option
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Chassis designer:use sheetmetal and solid in Creo Parametric & EZTol
2. What version of Creo Parametric are you currently running?
Creo 7.0.3 upgrade to Creo 7.0.8
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
We can’t select radius or diameter in Eztol stackup table. All circle dimension in Stackup table is Diameter.
We hope we can select radius and diameter.
And we hope if we change diameter to radius, the sensitivity and tolerance can change synchronously.
4. What is the use case for your organization?
We use Eztol to build TA stackup and generate TA report. But TA report is not only recorded and reviewed by designer, QA and Customers also have to check TA report. So how the TA generate report viewed impacts user experience.
5. What business value would your suggestion represent for your organization?
We can push Customer to accept to use EZTol more easily. And we can improve RD efficiency.
1 Comment
olivierlp
Community Manager
Thank you for your idea, @WeilingHong . Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
