I have an analysis on an assembly, and somewhere within this assy is a stress raiser. Due to the high value of the stress raiser, the range goes from very low, to very, very high. So i have a a lot of Blue on the analysis, and cannot locate the high point of stress amongst the components.
It's difficult to interrogate the less accesible areas, as the analysis is suppressed if any parts within the assy are turned off.
The Hide/Unhide feature helps, but it does not allow me to get the "Results --> Inquire" function into the difficult locations.
I would like to be able to fade away a percentage, or a range of results allowing the engineer to easily find or highlight specific areas of stress value.
(An alternative would be for the analysis/LBC's to not be suppressed when a part is turned off)
