Working with Creo and Windchill, you could have an assembly with a family table instance not verified:
I would like to have a column in the Model Tree with the values of 'Verification Stataus' in order to know that I am working with 'unverified instance'.
Config option verify_on_save_by_default yes helps you to verify before save, but I want access to the parameter 'Verification Statatus' from Creo, because it could be that this component is not new, was created by other user and now has 'released' Status in Windchill...
Thank you very much
