Family table option when replacing Extern Copy Geometry source
To improve the top-down design methodology when designing variations based uppon a skeleton that's a family table, we'd like to suggest this improvement.
Youtube unlisted video:
This is the setup:
A skeleton that contains a family table with the refs for a 3/4/5m machine, those refs are packed in a publish geometry.
That Published geometry is taken in with an external copy geometry and used in different features.
When saved to a new variant for 3Meter machine.
And the skeleton is renamed as well.
It's still looking at the original skeleton source for 4 meter.
We can do an edit definition and point to the source of the instance of 3 Meter, which has the same feature numbers and ID's.
But Creo doesn't treat the family table part as the same or connected, and all features fail:
So if there could be an option to replace the source parameter to a family table member, retaining the feature number and ID's, that would save a lot of time rebuilding all the dependent features.
Please mind this old idea , showing that it's somewhat possible if the machines would be a family table as well, though mind that a good advice for family tables is that the instances should somehow be 90-95% the same construction. It's no use having 3/4/5 meter variations of assemblies in a family table when they contain a lot of different parts.
Replace External Copy Geometry By Instance - PTC Community
Please mind that the demo-files are made in creo 7.0.6
3 Comments
olivierlp
Community Manager
Thank you for your idea and the information provided.
olivierlp
Community Manager
mwa
Maybe when using  Rename in session instead of Save as can solve your issue
