The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Fatigue advisor on non linear structural analyses
I would like to know if someone has been able to made a fatigue analysis (through the fatigue advisor extension), starting from a non linear structural analysis.
I know that it is not allowed by Creo Simulate, and I think that it could be nice to have.
In particular, the description of my problem: I have a static structural analysis on an assembly, with non linear interactions between components; then I'd like to make a fatigue prediction on each single component but unfortunately I cannot use the static structural analysis run on the whole assembly.
Does someone have a suggestion?
Elena
N.B : This Idea was originally created by Elena Dordoni‌ as a discussion
3 Comments
auijttewaal
7-Bedrock
Hi Elena,
Isn't it possible to recreate the stress on the separate parts by creating a static study with the contact pressure from the non-linear study applied as a pressure in the static?  (I agree it would be nice to have this done automatically in some way)
edordoni
1-Newbie
Hi Agnes,
this is a good idea. I also thought about that when I faced the issue.
But the point is: how can you export the contact pressure for each element and then apply it as boundary condition in a subsequent static analysis?
In the past I made the same using Ansys, but I don't know how to reproduce that in Simulate...
olivierlp
Community Manager
Status changed to: Archived
