Since at least Creo Parametric 2.0, three of the 45 degree chamfer settings are incorrect.
Default and Cd use a "C" abbreviation for chamfer, which is not recognized as valid in the ASME/ANSI standards.
Dx45 has lowercase "x" and no spaces in violation of the ASME/ANSI standards.
I filed a case and an SPR was filed:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS146957&source=Case%20Viewer
However, PTC refuses to acknowledge it as a bug and says it works to specification.
They had said they might fix it in Creo 4, but now the status is "No plans to fix"
PTC, please fix the 45 degree chamfer text so we don't have to customize every chamfer callout.
Here's a discussion about the C notation: Chamfer call out - Drafting Standards, GD&T & Tolerance Analysis - Eng-Tips
