All,
Asking community to vote on an existing SPR that has been sitting around since 2013.
SPR Details - 2863114 / 2180319 https://support.ptc.com/appserver/cs/view/spr.jsp?n=2863114
Description | When save_objects is set to changed, Selecting Review > Update Draft in an empty drawing file allows save .... |
Drawing behavior with the configuration setting save_objects=changed should behave the same way it does in a model. An unchanged drawing should not regen and mark the drawing as modified ("+" sign). Issue is amplified when working with lifecycle states in Windchill.
