When Creo creates a 3D PDF it would be nice if there was a way to control where the spin center is in Adobe Acrobat. I realize that the problem is probably related to the way Adobe implaments 3D objects but maybe you could work with them so we have more control over spin center.
There is a workaround here but, not a real solution: http://communities.ptc.com/message/249866#249866
