Fix Table Rotation Origin
In Pro/Engineer, a user was able to change the table origin and it would simply change the direction the table grew and the defalt point used to locate the table.
Now, in Creo Parametric, changing the table growth direction reformats the entire table and its contents, including switching the order of the columns, causing users to have to reformat any tables that simply need the origin changed.
This causes users to have to decide to spend time reformatting entire tables, or using tables as-is and moving the table every time there is a size change.
 PTC please fix this functionality so that tables remain in their correct format when the growth direction is changed.
2 Comments
dhermosillo
It looks like PTC has fixed this by re-adding the Set Rotation Origin command.
PTCModerator
Emeritus
Status changed to: Archived
