Fix copy & paste in drawing tables in Creo3 & Creo4
Current C3 & C4 functionality, copy the contents of a cell in a drawing table and paste it in another cell, the font and text size of the cell you are copying to is changed to default from what ever you had created it at.
PTC's workaround available in C3 M100+ was to bring back the old editor through PROPERTIES and paste there so as not to modify the text formatting.
Requesting an enhancement to make the EDIT/COPY/PASTE functionality exactly like Microsoft Word by including the ability to MERGE FORMATTING or KEEP SOURCE FORMATTING when performing the PASTE function.
2 Comments
MikkoHinkkanen
Copying the text from Repeat Region using CTRL+C (BOM) and then opening the required model using CTRL+O CTRL+V is often used functionality. Today it will not work with Creo 3 and Creo 4.
olivierlp
Community Manager
Status changed to: Archived
