Current set of default piping components/fittings located at <creo_load_directory>/text/piping_data/fittinglib/ are valid for Spec-Driven Piping only.
These fitting parts are missing datum points witch would enable their use in manual piping. Secondly these fittings have naming conflict in instances.
PTC See tech support case: C12412047, C12457308.
