Fix existing piping components
Current set of default piping components/fittings located at  <creo_load_directory>/text/piping_data/fittinglib/ are valid for Spec-Driven Piping only.
These fitting parts are missing datum points witch would enable their use in manual piping. Secondly these fittings have naming conflict in instances.
PTC See tech support case: C12412047, C12457308.
3 Comments
jpiotrowski
I have also noticed some issues with some of PTC's default fittings missing datum points and having a conflict withthe instances.
My company CadActive has a product RsysConfig that makes Spec-Driven Piping easier using automation. One of the tools of this product is the Fitting GUI which automatically creates the required datums (planes and points) based on the "in/out/branch" entry ports along with the needed parameters on the ports and in the fitting PRT itself.
Please check out our website here for more information.
Cheers,
John Piotrowski
CadActive Technologies
Co-Founder & Product Manager
JimBarrettSmith
olivierlp
Community Manager
Status changed to: Archived
