Hi PTC,
Please fix the following problem introduced in Creo 3:
Creo Simulate fasteners and materials fail instead of being suppressed while in a simplified rep causing meshing failures and analysis running failures or to terminate and fail.
Refer to PTC case number:13398407
Sample files of the problem have been attached to show the issue.
Basically you can't use simplified reps now as of creo 3 to run alternate design analysis.
Don Anderson
