The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Fix "Fix Index"
Fix "Fix Index"
Please make "fix index" work reliably.  This would include retaining a BOM bln (at least most of the time) when using the replace command in the assembly, as well as working with flexible components.
Fixing the index is a great idea to quicker match blns to their line in an automated BOM, and vice versa.  I like the idea, but it has been implemented in a VERY error prone way.
More Details below
PTC said this is intended functionality because they don't know how to handle situations where there is a quantity >1 for the item being replaced but a simple way to handle this might be to have it do a clean replace when qty is 1 and then if qty >1, then the replacing component will get a new number appended to the bottom of the table, and the remaining component(s) will retain the original number.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
