Fix the Cosmetic Groove Sketch Setup
Please fix the Cosmetic Groove Feature so that the sketcher works like any other Feature should.  Currently, if I Edit Definition of a Cosmetic Groove and then select "sketch", the sketcher comes up.  So far, so good.  However, if I now want to edit the "sketch setup", the Menu Manager pops up like some archaic way of changing the sketch orientation.  There isn't another feature I use that does this when going to the "sketch setup".  It poses particular difficulties when copying a cosmetic groove from one model and pasting into another.
Thank you in advance!
