Flexible Modeling. Change default Anchor APEX and Bending editing option settings (Values).
Could we add an option to change the default values (settings) when editing a bend to have Anchor Apex active and use "Constant wall Height" as default for Bending editing option. (to keep part dimensions the same).
In Sheetmetal Flexible Modeling 99.9998% of the time you when you want to change bend radii of a customer's solidworks/etc... file(s) that you converted to sheet metal, that is all you want to change is the Radii.
the default settings changes the position and height of the flange/flat. changing the overall dimensions of the customers part.
99.998% of the time you will not want to change the size of a customers part. just the radii to match your bending tools. The part dimensions should stay as in the original file by default.
